running pig rich
Old Mar 8, 2006 | 06:04 PM
camaroKid223's Avatar
running pig rich
car is running rich as crap, even with the new tune. The car has maybe 400 miles on the new motor with mods below, pulled it out after spending the winter parked and shes running rich as crap. black coming out the pipes real bad, running very very rough, fouling plugs very fast. any ideas what could be causing this?
Old Mar 8, 2006 | 06:07 PM
94Z396_0621's Avatar
Re: running pig rich
Have you had the car tuned yet? If not that may be your problem.
Old Mar 8, 2006 | 06:39 PM
Ion at madz28 did the tuning
Old Mar 8, 2006 | 07:33 PM
matt65's Avatar
Any exhaust leaks? Firing on all 8?
Old Mar 8, 2006 | 08:10 PM
runs on all 8 until it starts fouling plugs. doesnt seem to have any leaks but ill take another look tomorrow
Old Mar 8, 2006 | 08:23 PM
Alvin@pcmforless.com's Avatar
Try to get a datalog. There is likely a bad IAT or ECT or even O2, sensor
When the car is that far from right you can almost always bet its something mechanical.
Old Mar 8, 2006 | 09:55 PM
hellostop's Avatar
if the above is ok, try MAP sensor.
Take somwhere that can check voltage ranges on all sensors and knows what they're lokking for.
Old Mar 9, 2006 | 05:05 PM
I forgot that I left the IAT sim in there, so im thinking maybe that with the new tune are causing it to add extra fuel, then fouling the plugs and causing all of the idle issues?
Also very odd is that after start up the fuel pressure goes up to normal but once you shut the car down it bleeds off very fast.
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
97ss1826
Mar 13, 2003 11:58 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
