Running like crap, how to pull codes.
Old May 20, 2007 | 02:58 PM
z28 justin's Avatar
So I definately messed something up the other day when I downshifted really hard and bounced off the limiter a few times. I was sick of slow traffic and trying to get to work, it was dumb, I know. Now the car is running really rough and I can't really figure out why. It's not making any weird noises just runs like crap. (Note, I replaced my opti, plugs & wires just last summer). Anyway, how could I tell if I bent something in the valvetrain or worse? Would it throw a code?
Also, I was wondering what programs and cables you guys use to pull codes. Mine's a 95 with the OBDII connector but OBDI computer.
Old May 20, 2007 | 03:26 PM
Bent valvetrain parts won't throw any codes. You will need to scan the car with an OBD-I scanner and appropriate cable. Could be that you bent some pushrods. I would look there if you are feeling it miss.
Old May 20, 2007 | 03:28 PM
windsma's Avatar
AutoZone maybe able to use their diag.tool.
i think its just 96 and up.
worth a try and its free.
Old May 20, 2007 | 03:42 PM
2000GTP's Avatar
Autozone won't scan 95s either.
Old May 20, 2007 | 04:15 PM
z28 justin's Avatar
Can I just pull the pushrods out after removing the rocker arms, or should I take the intake off as well?
Old May 21, 2007 | 07:48 PM
lovescamaros25's Avatar
I am curious about this also.Isnt there a special cable you have to buy on the OBD1 93-95 Camaros.Also,where do you get it.I know you cant use a jumper wire on an LT1 Camaro.
Old May 21, 2007 | 09:27 PM
You don't need to remove the intake to remove the pushrods.
Old May 21, 2007 | 09:28 PM
95s need the special cable. Scanner manufacturers make the cable to go with their scanners.
Old May 22, 2007 | 05:51 PM
Actually, you can use jumper wire to short the ALDL pins and flash the codes on the SES light, for the 93 (only) LT1's.
Gtpguy
Jan 26, 2015 04:50 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
