Flycut the valves?
Old May 21, 2007 | 11:11 PM
rasputin's Avatar
Flycut the valves?
An engine builder told me that he would recommend a 3 angle valve job and a fly cut valve job to make my buddies heads (stock) flow a little better. What will that do in terms of power?
Old May 22, 2007 | 10:09 AM
Z28SORR's Avatar
Same answer as this question.: http://web.camaross.com/forums/showthread.php?t=522202
To me many of these things only make sense IF you are racing in a class that requires you to run "stock" parts. Or until you've gotten to a point where there isn't anything else left.
In other words you'd be better off spending the money on aftermarket heads then doing this on stock heads. Once you have the best aftermarket heads and intake, and still need a few more hp to be competitive, then it begins to be cost effective to do all these little details.
Although 3 angle valve jobs are not uncommon or much more expensive.
Old May 22, 2007 | 02:11 PM
rasputin's Avatar
coo thanks for the help Boss
Old May 22, 2007 | 07:52 PM
MachinistOne's Avatar
These heads have a 3 angle valve job and factory back-cut valves from the factory - if your machinist does not at least match the performance work that was there to begin with you need to take you motor somewhere else. A 3-angle VJ was "performance 20 years ago, now multi-angle and radius valve jobs are the norm.
We don't do anything less than 3-angles when cutting seats.
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
