Running Lean
Old Jul 3, 2005 | 08:50 AM
97formulakid's Avatar
Running Lean
How can I fix this???
Old Jul 3, 2005 | 09:34 AM
Re: Running Lean
How do you know its "running lean"? Do you have a wide-band chart showing the A/F ratio across the RPM range? Do you have data from the stock narrow band sensors showing low mV's? Do you have a scan that shows the BLM's? Under what specific conditions do you think its running lean... normal driving? .... WOT???
Old Jul 3, 2005 | 10:59 AM
Re: Running Lean
Well, I'm kinda guessing on it. First I heard that if your car runs lean it will run hot also, well it is running hot and I have done everything I can think of to the cooling system. 2nd, It smells lean when I am running the nitrous, and 3rd my kit is shutting off at the top of almost every gear so I suspect that it is going lean and the FPSS is shutting the kit off. It is all kinda guess work really, I am going to get a A/F ratio gauge when I get the nitrous pressure gauge and see exactly where it is.
grabbem88
Feb 13, 2015 03:09 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
TechCam97
Sep 12, 2002 07:20 PM
