running lean
Old Mar 23, 2005 | 09:57 PM
kcz28's Avatar
running lean
just wanted to know if it was
safe to drive while running lean (about 160 range on both sides)
Old Mar 23, 2005 | 11:51 PM
Re: running lean
The BLM's are maxed out. You need to find out what the problem is before continuing to drive it. If the BLM's were below 160, it would mean the PCM is able to compensate for the lean condition, and eliminate the possibility of engine damage. But once you max out the BLM's, you run the risk of actually running lean.
grabbem88
Feb 13, 2015 03:09 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
TechCam97
Sep 12, 2002 07:20 PM
