Running guideplates w/ SA Roller Rockers!
Old Dec 31, 2004 | 05:33 PM
  #16
slimdawson's Avatar
Re: Running guideplates w/ SA Roller Rockers!
[QUOTE=SStrokerAce] Those things do odd things in there when they are opening and closing the valve 50 times a sec
You spin your motor to 12,000?
Just joking man.
Old Dec 31, 2004 | 09:41 PM
  #17
Mtrhds94Z's Avatar
[QUOTE=slimdawson]
Just joking man.
'50 times a sec' x 60secs[ in a minute]=3,000 times that each valve opens/closes per min... x 2 'revolutions of crank per valve opening' = 6,000 crank rpm.. sounds about right to me.. where'd you get the 12,000 figure from?
Old Dec 31, 2004 | 10:13 PM
  #18
sseeya's Avatar
Originally Posted by arnie
Another one of those thread topics that has been beat to death. Either to lazy to do searches, or it just is not sinkin' in. Then, to top it off, bad/inaccurate info continues to be passed on/posted from thread to thread. As to the original poster, you've been had. Deal with it. Either rebuild them, or scrap them. Use them, then you deserve what you get. You acquired a worm/bad set of rockers. Sometimes, being 'blunt' is the better approach, when it comes to advice. Wouldn't be surprised if the goof you got them from, had run them with guide plates. You can lead a horse to water.....
Come on Arnie, don't hold back. Tell us what you really think.
Old Jan 1, 2005 | 03:20 AM
  #19
arnie's Avatar
Alright, it's a new year, I'll start it off a little easier/'lighter'. Maybe the 'hard hitting' journalism, wasn't the better approach here.
This topic is one of those, that has been discussed to ad nauseam. There should be plenty of info in archives for reference. The previous statement is also, for those that do not understand, and continue to post inaccurate info/recommendations. These rockers appear to be worn, and/or misused, from lack of a knowledgeable install. If the rockers, in the pic, are representative of the majority, I would consider the entire 'misused' set garbage, and not worth rebuilding. Even with filing and/or grinding of areas of interference, using them is not recommended, for any length of time. I certainly would not use them along with guideplates, as a crutch. Wouldn't surprise me, if original owner, installed them with guide plates. That, or ran them extremely loose. I realize, it doesn't sound good, but I consider the purchase, a poor investment.
Old Jan 1, 2005 | 04:01 PM
  #20
SStrokerAce's Avatar
Yeah and that was just a 6,000rpm example
Old Jan 1, 2005 | 04:11 PM
  #21
slimdawson's Avatar
Wow. I didn't even want to reply to bring this post back to the top. My mistake on the math. I was hurriedly thinking 4 stroke and thought 4 revs of the crankshaft per cycle instead of 2. Thanks for making me feel like a loser.
oldschool
Feb 9, 2016 09:21 PM
1775.Z28
Jan 11, 2015 10:51 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
