Running 30# injectors untuned
Old Nov 30, 2004 | 04:03 PM
  #16
Re: Running 30# injectors untuned
Once you put the correct flow rate into the PCM, you are done. It will run exaclty the way it did with 24# injectors. You still have the option to use the PE tables to lean out the WOT A/F ratio. Separate issues.
I was a little hesitant to even answer this, since you weren't happy with my post in the captain_foustas thread.... hope you aren't harboring some sort of grudge here???
Old Nov 30, 2004 | 04:09 PM
  #17
dmoor88's Avatar
That post was a completely different issue. Nothing against you as a person, just commented on how all the 'old schoolers' stick together.
Old Nov 30, 2004 | 05:36 PM
  #18
Rockin94Z's Avatar
think of it this way you car would still think it has stock injectors in it when it actualy has 30#. it will be dumping so much fuel into that thing that itd probably just fill the whole cylinder with fuel. just get a mail order tune. cheap about 80 bucks and then you should be fine
Noenav
Mar 1, 2019 07:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
birdblack
Dec 30, 2014 06:59 PM
nophix
Nov 30, 2014 10:26 PM
