Rules for adjusting the headlights?
Old Mar 6, 2004 | 06:01 PM
stereomandan's Avatar
After the body shop did a little work on the nose of my car, the lights don't seemed aligned properly.
Isn't there a rule, like "at X distance from a wall, the light from the headlights should be X distance above the ground"?
Dan
Old Mar 6, 2004 | 06:02 PM
nitropatch's Avatar
i did mine 5 to 7 feet from a wall and it works good but it all on how you want to do it, pry have to play with it.
Old Mar 6, 2004 | 06:06 PM
Actually, I found the answer while searching on Yahoo. Nice article.
http://www.autooptiks.com/aiming.html
Dan
Spinner's Avatar
Just adjust them at night. Do it until you get maximum vision.
Old Mar 6, 2004 | 06:08 PM
RedHottG2's Avatar
There is an indicator with lines and a bubble in it that helps you to align your lights. This should get you close. If that doesent work, I would take it back to the body shop and see if they would fix it for you.
Old Mar 6, 2004 | 07:23 PM
I got it, following the article I linked to. Worked great. Yeah, it's dark out now and it worked well. I've done it before, but didn't have the instructions anymore.
Dan
P.S. I'm aware of the bubble levels, but they have always been way off.
G-BODYT56
Jan 14, 2022 11:14 PM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
Greg88
Sep 20, 2015 07:14 PM
jackpawt883
Sep 10, 2015 08:53 PM
