RR's
Old Jul 14, 2003 | 09:38 PM
hey01's Avatar
RR's
im just looking for an easy bolt on right now.
would 1.6 RR's be a good next mod with the stock cam?
should i keep the stock springs or replace them as well??
what kinda gains should i see??
i did a search 1st but everything is just people having problems with RR's or deciding what kind to buy
Old Jul 14, 2003 | 09:42 PM
Got-LT1's Avatar
I went with comp cams 1.6rr. Very worthwhile to me. The car pulls a lot harder on the top end. Most people see around 10 hp in stock form but mild modded people have seen 15-20. I don't know what I picked, haven't bee to dyno Also they are pretty easy to install.
My $.02
EDIT: I used the stock springs...for now, until cc306 time
Old Jul 14, 2003 | 09:46 PM
hey01's Avatar
do you lose some bottem end??
when i took my cat off i noticed a slight loss from the bottem but it pulled very strong on the top
Old Jul 14, 2003 | 09:56 PM
Got-LT1's Avatar
No lose on the boottem end. It pulled better through the whole rpm range but was most noticalbe on the top end. the reson you lost bottem end when you took the cat off was that these cars are designed to run with a cetrin amount of backpressure, if the cat bhoters you just get a high flow cat.
Old Jul 14, 2003 | 10:02 PM
hey01's Avatar
cool i guess this will be my next bolt on
replace springs too???
i guess i should go ahead and get a LT4 KM too
no way im putting a cat back on it sounds too good and now it idles so smooth you can't even tell its in gear when your at a stop
Old Jul 14, 2003 | 10:08 PM
Got-LT1's Avatar
Like I said, some people do run 1.6rr with stock springs, won't hurt. It will be close to coil bind, but neither I or any of my friends have had that problem. I am just going to change my springs when I do the cc306, I am not comftable changing springs with the heads on the engine, might drop a valve (been there down that ).
As for the cat, it is lound isn't it , My friend took his off his and it was lound as hell.
Old Jul 14, 2003 | 10:16 PM
Lunarson's Avatar
You can reuse the stock springs temporarily but there's very little room for error when setting the lash. 1/4 turn past zero lash will be about all you can get, some repair manuals suggest 1/2 to 3/4 past zero lash with stock 1.5 RA's. If you go more than a quarter turn you run the risk of coilbind.
Old Jul 14, 2003 | 10:23 PM
hey01's Avatar
sounds like i should just go ahead and get some springs and retainers while im doing the job!!!!
