rpm range for a 210/224 112lsa cam!!
Old Nov 29, 2004 | 12:22 AM
crAzy95z28's Avatar
i would like to know where the most power is on this kind of cam?
havent been to the dyno yet, but iif any one has anything let me know!!
Randy
Old Nov 29, 2004 | 05:46 AM
Tom Piper's Avatar
Re: rpm range for a 210/224 112lsa cam!!
Your signature indicates that the cam is a Comp Cam.
I have a cam with the same exact specs that is a Crane cam. Crane advertises idle to 6K rpms for their cam.
Tom Piper
Old Nov 29, 2004 | 08:33 AM
ishz28's Avatar
I have the Crane Compucam 210/224 as well. My cam card advertises the power range as 2K to 6K.
Old Nov 29, 2004 | 09:03 AM
rskrause's Avatar
Moderator
Seems to me like it would pull to just a bit below 6K.
rich
Old Nov 29, 2004 | 09:50 AM
BUBBA's Avatar
It's a stump puller cam.
Old Nov 29, 2004 | 09:57 AM
truedualws6's Avatar
It's effective range is probably more like 2,000 to 5,800. You can see from
the dyno graph it falls off at about 5,800.
Crane 227 Dyno Graph
Just ignore the jaggies. I have not figured out that problem yet. I have managed
to install lots of new parts that did nothing to fix it. Nothing like a good
mystery to keep you going.
Old Nov 29, 2004 | 11:45 AM
stereomandan's Avatar
Like truedualws6 said, it's probably in the very high 5k area that the power peaks. Remember though, peak power is NOT where the optimal shift point is. The optimal shift point is going to be much higher in RPM, but is limited on our valvetrain stability.
Dan
Old Nov 29, 2004 | 12:52 PM
crAzy95z28's Avatar
well the box says comp crane cams! so i went ahead and put that!!
but my 2-3 shifts at around 6200-6300 rpms and when it shift it shifts HARD!!
thaks to the all mighty shift kit!!
but yea, i just wanted to see where it fell off at!!!
thanks for the replies!!
Randy
carl.froehlich
Mar 13, 2015 12:38 AM
edman
Jan 22, 2015 02:45 PM
Red_94Formula
Jan 22, 2015 12:17 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
