Rpm
Old Aug 21, 2005 | 02:30 PM
redstriper05's Avatar
Rpm
Hey guys on here agian. Like I said just rebuilt the engine and now my rpms are showing on the gauge. the neddle is dead like the car is off but it is running. anbody know if there is a plug up or something I missed?? Thanks
Old Aug 21, 2005 | 11:08 PM
Re: Rpm
I assume you meant the RPM are NOT showing on the tachometer???
The tach gets its signal from pin A13 on the PCM.
Might want to mention at least the year of the car.
Old Aug 22, 2005 | 05:55 AM
Re: Rpm
ya the needle on the tac is dead. It a 96 z. i just need to know is there a plug for it, i thought it was on the coil, but I'm not sure
Old Aug 22, 2005 | 09:05 AM
Re: Rpm
The wire doesn't come from the coil... its a white wire, and it comes from pin A13 on the PCM (#13 on the "red" connector). The wire runs through the firewall to the dash. In a 95, its in connector C230.... not sure if its the same in the 96.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
