Rpm
Rpm
Hey guys on here agian. Like I said just rebuilt the engine and now my rpms are showing on the gauge. the neddle is dead like the car is off but it is running. anbody know if there is a plug up or something I missed?? Thanks
Re: Rpm
The tach gets its signal from pin A13 on the PCM.
Might want to mention at least the year of the car.
Re: Rpm
The wire doesn't come from the coil... its a white wire, and it comes from pin A13 on the PCM (#13 on the "red" connector). The wire runs through the firewall to the dash. In a 95, its in connector C230.... not sure if its the same in the 96.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
