Royal Purple?
Old Sep 16, 2004 | 09:04 PM
brians96Z's Avatar
Royal Purple?
Has anyone used the Royal Purple ICE or whatever it's called. It's for your radiator, and is supposed to help your car run a little cooler, and keep water pump seals lubed. What do you guys think?
Old Sep 16, 2004 | 09:15 PM
LT1Squirrel's Avatar
Re: Royal Purple?
im not really a big supportive of additives...but have you tried running a diff ratio of h20/coolant?....whats your current ratio?
Old Sep 16, 2004 | 10:49 PM
brians96Z's Avatar
Re: Royal Purple?
50/50 I have to be careful, though, we have some cold winters here.
Old Sep 17, 2004 | 02:21 PM
Re: Royal Purple?
i forgot who said it or where i read it, but water has 4x the dissipation capabilities of coolant, runnin 70/30 should still get you thru the winter IMO...and if you dont feel safe, change it back to 50/50 around november...
Old Sep 17, 2004 | 04:00 PM
BoobSter-lt1-z's Avatar
Re: Royal Purple?
I havent tried the coolant additive yet but i did try their engine and tranny oil and from all other brands like castro, mobil, and valvoline, this is the best bang for the buck. car runs much smoother and has better accelaration and the tranny shifts smoother on low accelaration shift and nice firm shifts at 6k rpms when flooring it.....
Old Sep 17, 2004 | 05:31 PM
96capricemgr's Avatar
Re: Royal Purple?
Unless you have a cooling system problem the stat and fans control temp, stuff like this only helps lower temps if your cooling system in inadequate.
gonzo275rltw
Jul 10, 2015 11:47 AM
jl1ne
Jul 7, 2015 08:38 PM
Koby
Jun 28, 2015 04:46 PM
phantasm99
Aug 28, 2002 11:01 PM
ssbee
Jun 12, 2002 12:03 PM
