Routing OTVC wires.
Old Mar 27, 2004 | 08:29 PM
Cmr0z28's Avatar
Routing OTVC wires.
Ok, driver side is simple....now the passenger side....
Do I go where the stock wires went, between the power steering pump and A/C compressor? Between power steering pump and alternator? What do I do?
Old Mar 27, 2004 | 08:42 PM
Lt1dtpower's Avatar
Thats what I did.
Old Mar 27, 2004 | 09:08 PM
Cmr0z28's Avatar
What did you do? I gave more than one option, lol.
Old Mar 27, 2004 | 09:16 PM
696redZ-28's Avatar
I installed Between power steering pump and alternator but used the high temp heat shields put 2 wires in each to protect wires from sharp edges.
Old Mar 27, 2004 | 11:36 PM
Cmr0z28's Avatar
Old Mar 27, 2004 | 11:41 PM
ibanez6rg's Avatar
Mine go up behind the p/s pump and behind the alt. on top of the valve cover.
Old Mar 28, 2004 | 12:20 AM
CamaroBoy96Z28's Avatar
I went through the stock location. I have an ok pic of it in my sig but I'll have a way better one tomorrow or monday.
Old Mar 28, 2004 | 09:12 AM
Cmr0z28's Avatar
Ok thanks.....I took all the plugs out yesterday, now for the passenger side wires, I took off one of those stock looms from the bottom, is there another one holding them in? When I tug on them they don't wanna come out, and I can't see in there.
Old Mar 28, 2004 | 10:51 AM
Theres one long loom that raps around the acc. bracket and follows it down behind the pulleys to keep the wires from getting mangled in the pulleys.
Old Mar 28, 2004 | 11:04 AM
Cmr0z28's Avatar
Ok. How do I get it off?
Old Mar 28, 2004 | 11:25 AM
Cmr0z28's Avatar
TTT I need this answered ASAP!!!! PLEASE! I have to finish this by today!
Old Mar 28, 2004 | 01:01 PM
Cmr0z28's Avatar
Old Mar 28, 2004 | 07:20 PM
696redZ-28's Avatar
Its been a while but I'm sure i cut the wire ends by the opti and pulled hard! hope this helps I also guess your not using a lift? that makes life so much easier!
KYWes
Jun 14, 2022 06:52 AM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Pestilence
Aug 18, 2015 06:19 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Thirim
Jul 30, 2015 01:29 PM
