Rough starting
Old Jul 12, 2004 | 12:52 PM
hashimsaleh's Avatar
Rough starting
All of a sudden i go to turn my car on..and it doesn't start right away ... sometime i have to turn the key twice...and it starts the second time with alittle gas of course
i just replace the fuel pump, filter, spark plugs, and wires
it feels like its not getting gas or a spark or something
any advice is great
Old Jul 12, 2004 | 01:08 PM
A few possibilities:
Have you checked the coolant temperature sensor? It needs to tell the PCM the engine is cold, so it can richen up the mixture for cold starts.
Did you check the fuel pressure? Does it hold 42psi after you shut the engine down?
Have you checked for leaky injectors? Dripping injectors could be loading up the cylinders with fuel at shutoff. Opening the throttle part way would help flow more air thru the cylinder to evaporate it at startup.
Old Jul 12, 2004 | 01:52 PM
n2ceptor's Avatar
My car is the same way.. Some mornings it starts right away, and other times it doesnt.... I just think its tempermental.....
And I have changed all the sensors....
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Scottylt1
Jan 8, 2015 02:48 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
