Rough idle, running rich
OK, i'm a moron. What are you referring to when you say bellows
I am sorry my mistake.
Marvin
two more things to check out in case you havent.
I learned that when the Fuel presure regulator diaphragn brakes.. the car leaks gas into the intake manifold... runs rich and rough..
Also a Burnt or bad plug wire will do the same... rich and rough..
if you havent checked. give it a try
Marvin
Marvin
I had a thought, tell me what you think. Due to the fact that the previous owner descreened the MAF and that I found a drill hole in the drivers side wheelwell, he must have had a CAI in the car and removed it when it was sold. Drill hole being from the block plate for the CAI. My question is: Do you think that putting the stock air filter set-up back on is causing some of my problems? Maybe the PCM never really adjusted back to the stock air intake. They seem to be pretty tempermental. I plan on buying a CAI. Maybe it will eliminate some of my problems. Just wishful thinking.
F(ast)-body
Feb 26, 2003 09:05 AM
