rough idle gas smell
Old Aug 2, 2007 | 06:22 PM
Daniel6718's Avatar
i think my charcoal canister is full. outside the car smells like gas by the rear driver tire but not inside the car or other side...must be the canister...my question is can this cause the car to die...it just started doing it today also...if you rev it up its fine but if it sits ideling once hot for about 2 minutes it will idle down and die...
now it runs rough all the time...
i also removed the line that comes into the engine bay along side the fuel lines and it WREAKs of gas and burnt my nose smelling it...i blew into it and could barely push though...
Old Aug 2, 2007 | 06:49 PM
SS RRR's Avatar
I'd check out your plugs/wires first.
Old Aug 2, 2007 | 09:55 PM
Daniel6718's Avatar
theyre fine...just did...not because injectors or plugs/wires it surges sometimes seems like avacume leak but its not checked them also...gota be this canister...
ive got one fast lt1 and one stocker...never had a problem with canister ever, this canister only has 95k on it...racecar was fine at 140k
markzzzz
May 8, 2015 09:21 AM
lt1matt
Mar 21, 2015 07:35 PM
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
