rough idle/bad throttle response=>ecm changing always open/closed loop!
Old Mar 3, 2007 | 07:51 AM
night-rider-69's Avatar
Hello!
A few days ago I entered the forum with the problem above:
Rough idle/bad throttle response. But the engine starts normal, cold and hot. The rough idle starts after warming up.
Now I used a scanning software and the only thing I noticed was that the engine is always changing between open and closed loop. Could this be normal?
The O2-sensors always have arround 0.5 V. I think this is ok, isn't it?
Last weekend I disconnected the O2 sensors but without any reaction to idling.
Perhaps I could send the data (From TTS Datamaster) to anyone who could handle these data better than me => You're welcome.
Old Mar 3, 2007 | 08:41 AM
MEAN LT1's Avatar
Originally Posted by night-rider-69
Hello!
The millivolts from the o2 sensors should be bouncing around once the car is properly warmed. If the numbers are stagnet then I would go ahead and replace them. Bad or slow o2 sensors can cause the the ecm to go from open to closed loop as described.
DirtyDaveW
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
94Form
Feb 10, 2015 11:23 PM
Ricardo
Nov 29, 2014 10:58 AM
Jul 4, 2005 05:00 PM
