rough idel
Old Nov 3, 2003 | 11:20 AM
93transam1234's Avatar
rough idel
My car has a small shake to it when it is ideling (in drive and in park) I have changed just about everything
Wires/plugs
coil
IAT
MAF
Fuel Filter
What else can be checked?
Can a shop check what Cyl are missing how much does that cost?
I want to get my car running perfect befor i do the HOTCAM kit.
Old Nov 3, 2003 | 11:39 AM
Your 1997 (assuming that is what you have, based on your screen name) is OBD-II. That system provides a misfire count, by cylinder.
Old Nov 3, 2003 | 11:43 AM
BigJustinZ28's Avatar
did you check the Idle Air Controller solenoid (IAC) ??? sometimes it gets gunked up and it will make your car idle badly , its the black thing on the bottom passenger side of the throttlebody. If you take it out and clean it with throttle plate cleaner and a toothbrush it will sometimes fix it. I just did that this weekend and it got rid of the stumbling my car does when its cold . Just be careful with it dont move the piston on it up or down or youll misalign it.
Old Nov 3, 2003 | 11:56 AM
RallyRed701/2's Avatar
ive always heard about the iac but ive never seen it exactly... does anyone have any pics of what it looks like. my car (94) also has a problem with a funky idle... like its missing, but its just at idle. so im still kind of confused as to what is causing the rough idle... how long does it take to take out the iac? is it difficult to do???
Old Nov 3, 2003 | 11:59 AM
Red5.7's Avatar
From shoebox
Old Nov 3, 2003 | 12:14 PM
you gotta take off the throttle body , its not too bad . The most time will be wasted on getting the damn water hoses off the t/b. I went ahead and did the t/b bypass while I had it apart since it never gets that cold here anyways. go to this site http://csce.uark.edu/~jgbertr/rb/4th_gen_tech1.html
it has the t/b bypass and iac location on it , this is the site I used to do both . It didnt take me more than an hour although I had a friend working on the bypass while I cleaned the throttlebody and IAC . You might wanna get a t/b gasket if you think yours may be worn and your not near a napa or something.
Old Nov 3, 2003 | 12:50 PM
yeah
i bought a new IAC a few weeks ago..
where would be the cheapest place to get my missfire count checked?
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
