Rotating Ballancer 90 deg. ???
Old Nov 3, 2003 | 01:36 PM
  #16
S.J.S.'s Avatar
Originally posted by Hotwire
actually it's a brand new napa belt, the old one got chewed up when I snapped the power steering bolts. not the best quality belt, but got it for cost..
From what you describe though sounds like a belt. Have you ever had belts do that on you? If so then you'd know. Hmmm. thats a tough one if it aint the belt.
Old Nov 3, 2003 | 02:21 PM
  #17
Hotwire's Avatar
I know it's the belt. for some reason the ribs on the napa belts aren't that deep, so I am just assuming they don't grip as well as others, plus, unknown mileage/abuse on the tensioner, I'd just as well have the belt slip like that than put the shock of the instant rpm shift into the accessories, my 97 4.3 S-10 5 speed does the same thing if I dump the clutch when catching gears (napa belt too).
I don't feel it's a problem, just the programming has pretty aggressive shift pattern, going into third it's right on the verge of chirping the tires when you are 1/3+ into the throttle, so you know the motor is going from around 3-4 grand down to 1-2, I could soften the shifts up, but tooling around easy on the throttle if shifts like stock.
Old Nov 3, 2003 | 03:32 PM
  #18
anaik's Avatar
The Goodyear belt is supposed to be 100% better.
Old Feb 29, 2004 | 12:04 AM
  #19
licerio's Avatar
IS THIS VIBRATION PROBLEM BEEN SOLVED YET, IF SO PLEASE LET ME KNOW WHAT YOU DID, I'M HAVING EXACT SAME THING.
Old Feb 29, 2004 | 12:37 AM
  #20
94blackz14.2's Avatar
No I haven't figured out the problem yet. I just replaced both motor mounts think that might have something to do with it but it didn't change. I am now thinking that my harmonic balancer is probably worn out and is causing my problems. It does have 110k on it. As soon as I can save a few bucks I will be getting a new balancer.
Old Feb 29, 2004 | 12:45 AM
  #21
licerio's Avatar
i dont know if you changed it yet, but have you check, balance or replaced your flywheel yet?
Old Feb 29, 2004 | 10:43 AM
  #22
Hotwire's Avatar
I haven't replaced my flywheel, but I did get a keyed crank hub from thunderracing.com and I changed out my converter. it seems better, still feel a little vibration, don't know what it could be..
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
cmsmith
Aug 27, 2015 06:37 PM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Redbird
East South Central
Dec 14, 2002 09:58 AM
