Rotating Ballancer 90 deg. ???
Old Oct 26, 2003 | 10:47 PM
94blackz14.2's Avatar
I just read in an old post that you can rotate the harmonic ballancer 90 degrees to see if it helps reduce vibrations. I currently have a vibration that accurs in my motor when I am in nuetral and rev it to 2,000-2,500 rpms. This also makes the car vibrate in gear when I am crusing in that rpm range no matter what gear I am in. I was just wondering if this is true and if it would be worth my time to try it.
Old Oct 26, 2003 | 10:56 PM
IMO, the only reason you might want to try that is if you have reason to believe that the position of the hub had been altered from stock. You might want to be sure you just don't have a miss.
Old Oct 27, 2003 | 09:01 AM
95 Z/28 LT1's Avatar
Super Moderator
This fix for "engine wobble" is mentioned in the factory service manual and is also referenced to in the book that is out about rebuilding the LT1/LT4 engine.
Old Oct 27, 2003 | 09:03 AM
RamAir95TA's Avatar
The balancer/hub is zero-balanced, so I don't see how it would help.
Old Oct 27, 2003 | 10:36 AM
stew's94z's Avatar
It also has three holes so you can only turn the harmonic balancer 120 degrees on the hub. It would take four holes to turn 90 degrees.
Dean
Old Oct 27, 2003 | 11:04 AM
CamaroBoy96Z28's Avatar
Dean
That and the balancer only goes on the hub one way.
Old Oct 27, 2003 | 11:09 AM
Hotwire's Avatar
Dean
The hub is not keyed on the crank, it is press fitted on there. you can turn it however you want.
Old Oct 27, 2003 | 11:28 AM
stew's94z's Avatar
True.
Dean
Old Oct 27, 2003 | 11:33 AM
Super Moderator
I meant to turn the Hub, not the balancer. As stated above, the balancer only mounts to the hub one way.
Old Oct 27, 2003 | 11:57 AM
Here's the refererence found in "Rebuilding the LT1".
HUB AND BALANCER
The balancer is a two-piece assembly with a pulley that bolts onto the hub. Separating the two made it easier to install the Optispark distributor on the assembly line and out in the field. The holes in the hub are offset, so the balancer only fits on it one way, but there’s no keyway in the hub to index the hub on the crank. This shouldn’t be a problem unless the damper was drilled at the factory to "trim" the final engine assembly.
If it was drilled a lot to compensate for an engine that was out of balance, you could end up with a shaker, depending on how everything stacked up with the remanufactured engine compared to the original engine. If you encounter a balance problem on a remanufactured LT1, try rotating the balancer assembly on the crank 90° at a time to see if it eliminates the problem.
Old Oct 27, 2003 | 03:47 PM
Super Moderator
I wonder what could cause this wobble to start happening a while after the engine has been rebuilt. Say 10-20,000 miles for example.
I have this problem with my rebuilt engine and it started after I changed the clutch. I put the original PP back in after it started happening because I figured that it caused the problem and the wobble has stuck with it ever since.
I still have the same flywheel too.
Old Nov 2, 2003 | 08:10 PM
S.J.S.'s Avatar
I'm putting my motor together and was wondering (when putting a motor together thats not good to do) this. When I put my hub on, it can just go on any way???? There is no keyway but the manual says to mark it when removing and replacing. Why is this?
Thanks.
Old Nov 2, 2003 | 08:22 PM
Hotwire's Avatar
for some reason the factory didn't think it was necessary to put a keyway on it, and for the most part it works just fine.
in the service manual it says to find TDC and place the hub so the arrow is straight up.
95, could have wound out or hub spun a little causing it to become off balance. Everything is supposed to be neutral balance from what I have read, but check your balancer to be sure that none of the elastomer is sticking out, that would tell you the pulley spun on it's hub and it's no longer good.
Thats one thing I'm worried about w/ this LT4 conversion and programming, when I'm about 1/3 throttle and it drops into 3rd, you can hear the fan belt chirp, I'm just wondering when it's going to take the pulley w/ it..
Old Nov 2, 2003 | 09:25 PM
S.J.S.'s Avatar
That's just an old belt from what it sounds like.
Old Nov 3, 2003 | 11:35 AM
Hotwire's Avatar
actually it's a brand new napa belt, the old one got chewed up when I snapped the power steering bolts. not the best quality belt, but got it for cost..
