ross nitrous pistons and ring selection?
Old Jul 15, 2005 | 03:06 PM
djm_e22's Avatar
I have some ross pistons that can supposedly handle a 250 shot of nitrous, can anyone help me select the rings I should get. Also I plan on putting 150-200 shot on these, if anyone needs to know this. Thanks for the help.
Old Jul 15, 2005 | 03:22 PM
sssalah's Avatar
Re: ross nitrous pistons and ring selection?
Setting the correct piston to bore clearance and file fitting the rings with the required clearance for this application is most important. I had good luck with seal power standard tension plasma moly coated rings.
mmf_1013
Sep 12, 2015 08:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
blaze309
Sep 8, 2015 05:27 PM
CARiD
Sep 7, 2015 08:21 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
