Roller Rockers Info
Old Jul 15, 2004 | 11:41 PM
CColtManM's Avatar
Roller Rockers Info
What is the stock roller rocker ratio for a 97 LT1 Camaro? And what is a good ratio to upgrade to?
Old Jul 15, 2004 | 11:44 PM
Robs97Z28's Avatar
1.5 stock/ 1.6 cc pro mags
Old Jul 15, 2004 | 11:47 PM
CColtManM's Avatar
So those are both stock?
So all the 1.6's on Ebay are stocks... is that .1 really a big difference?
Old Jul 15, 2004 | 11:54 PM
disco192's Avatar
well it is a ratio. The 1.6 will net you 6.6% more lift, producing more power.
Old Jul 15, 2004 | 11:56 PM
jkayner's Avatar
check out my instllation page if you want to do the work yourself...
CColtManM's Avatar
How much power does each .1 give me about?
Old Jul 16, 2004 | 12:00 AM
LWillmann's Avatar
1.5's are stock
1.6's are upgrade, that guy above was recommending you step up to 1.6 Pro Magnum from Comp Cams.
if you want to stick with the stock cam, you can go with some 1.7 rockers with some better springs. You can use the 1.7's with some aftermarket cams, but you might end up with too much lift if you don't watch it.
Old Jul 16, 2004 | 09:44 PM
Bud M's Avatar
1.6 rockers are a worthwhile upgrade. You will need to do springs too. I used LT4 springs with mine. http://www.streetillusionsracing.com/RR/rr.htm is a good install guide.
oldschool
Feb 9, 2016 09:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
MadMav
Jun 15, 2015 09:51 PM
dfarr67
Apr 10, 2015 07:44 PM
Roadie
Feb 16, 2015 10:34 AM
