roller rockers
Old Jul 21, 2007 | 07:24 PM
  #16
Oxygen454's Avatar
Thanks ChevyTuffD.A. I was watching the video and I thought maybe that there was intake on one said of the rocker and exhaust on the other. I think where I see where I went wrong. How many rockers are there on a v8 per side?
Old Jul 21, 2007 | 07:37 PM
  #17
aboatguy's Avatar
2 per cylinder
8 per side
16 total
Old Jul 21, 2007 | 08:19 PM
  #18
Oxygen454's Avatar
Okay that makes sense, one for exhaust and one for intake. So that makes 8 per side.
Old Mar 16, 2008 | 02:18 AM
  #19
Oxygen454's Avatar
haven't had a chance to do the lifters yet, few months later haha. What do I have to do in order to adjust with the car running? It seems the easiest to do. This way I dont have to pull the belt off and turn the engine to find the correct up and downs on the exhaust and intakes. Do I need some old valve covers cut open at the top or can I get away with out with no oil covering my engine? lol
(just a side note, the rockers are stock, not roller)
Old Mar 16, 2008 | 03:16 AM
  #20
'94 Bad A Z28's Avatar
Here is a broken SA rocker, but this is what is "should" look like if it is infact a SA rocker.
Old Mar 16, 2008 | 03:17 AM
  #21
Of course minus the bentness and broken offness, lol.
Old Mar 16, 2008 | 12:28 PM
  #22
Oxygen454's Avatar
Thanks for the info '94 Bad A Z28.
Does anyone know if I need some old valve covers cut open at the top or can I get away with out with no oil covering my engine?
Old Mar 16, 2008 | 01:55 PM
  #23
97ChameleonTA's Avatar
Moderator
I usually just cut a piece of cardboard the length of the head and about 6-8" tall. I place this in the area between the valve springs and the valve cover lip. This prevents the oil squirting from the pushrods from making a mess.
Old Mar 16, 2008 | 02:24 PM
  #24
Oxygen454's Avatar
Great! Thanks for the tip! Now I just need to borrow a torque wrench and find my gaskets and Im off! haha
Old Mar 16, 2008 | 05:17 PM
  #25
Moderator
Torque wrench????? For what?
Old Mar 16, 2008 | 06:27 PM
  #26
Oxygen454's Avatar
You have to torque the bolts down and in the right pattern or you will get leaks or you could over tighten the bolts stripping the threads.
Old Mar 17, 2008 | 10:30 AM
  #27
Moderator
Are we still only talking about installing new rocker arms?
If so, then in no way, shape or form should you be using a torque wrench. It may be in your best interest to find someone local to you that has done this before that can give you a hand.
Old Mar 17, 2008 | 01:57 PM
  #28
Pro_built7's Avatar
what bolts ??? you don't need a torque wrench to adjust rockers. are you talking about studs? huh...
Old Mar 17, 2008 | 11:55 PM
  #29
Oxygen454's Avatar
Sorry Im talking about torquing the valve covers down. Sorry about the confusion haha. Rockers, no you don't need a torque. lol Im tearing it apart this weekend, should be easy.
Old Mar 18, 2008 | 09:11 AM
  #30
Moderator
You really don't need a torque wrench to do that either. Just make sure they are snug with a 1/4" drive ratchet. Go easy and you won't have any problems.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
