Roller Rocker Question
Old May 6, 2005 | 06:53 PM
Johns LT1's Avatar
I am about to buy the CC305 and was wondering if there was anything that I had to do to my heads to make the Roller Rockers work? I heard that you have to machine your heads. Are they direct bolt on or do I need to do anything else. My heads have been ported and polished and have heavy duty valve springs on them already.
Old May 6, 2005 | 08:28 PM
joeSS97's Avatar
Re: Roller Rocker Question
As long as you get the right size for the studs(3/8 or 7/16") they will bolt right up.The only problem you might have is with the valve covers.You may have to remove the bracing inside.Not a big deal.
Old May 6, 2005 | 10:08 PM
ChrisUlrich's Avatar
Go XE Comp Cams...
Old May 6, 2005 | 11:49 PM
rskrause's Avatar
Moderator
If you are getting aluminum rockers they need to be the narrow body style for center bolt valve covers.
Rich
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
