Roller Rocker Question
I am about to buy the CC305 and was wondering if there was anything that I had to do to my heads to make the Roller Rockers work? I heard that you have to machine your heads. Are they direct bolt on or do I need to do anything else. My heads have been ported and polished and have heavy duty valve springs on them already.
Re: Roller Rocker Question
As long as you get the right size for the studs(3/8 or 7/16") they will bolt right up.The only problem you might have is with the valve covers.You may have to remove the bracing inside.Not a big deal.
oldschool
Feb 9, 2016 09:21 PM
