rods and pistons for LE heads and cam
Old Jun 29, 2008 | 12:31 PM
  #16
96capricemgr's Avatar
Those are 600+ grams, stock is 532g. Check out this post by Bret.
http://web.camaross.com/forums/showp...5&postcount=18
Old Jun 29, 2008 | 01:07 PM
  #17
MachinistOne's Avatar
https://www.camaroz28.com/forums/sho...5&postcount=18
In addition it has a 5/64" ring pack
Old Jun 29, 2008 | 03:09 PM
  #18
NightTrain66's Avatar
There are just not many piston choices in that price range. Maybe spend a lil more and get an SRP/Mahle . . . . . ?
Lloyd Elliott
972-617-5671
Elliottsportworks.com
Old Jun 29, 2008 | 03:12 PM
  #19
The TRW/Speedpro pistons are ok for a gen I motor done on the cheap where forged is a concern. But the later model motors all use thinner ring packs and lighter pistons, where by using those heavier slugs you are doing more harm than good. Pony up the extra $100 and get a set of Mahle or Wiseco pistons.
Old Jun 29, 2008 | 03:38 PM
  #20
aboatguy's Avatar
Originally Posted by NightTrain66
Focus on quench and compression. measure the deck ht once it is all back together and use a head gasket that gives you a .030-.035 quench. Probably gonna need some .026" Mr Gasket 5716 heads gaskets to get there assuming the piston ends up .004-.010 in the hole at TDC.
Lloyd Elliott
972-617-5671
Good advise higher static compression help tame big cams!
Originally Posted by MachinistOne
Why does everyone insist on running heavy H-beam rods, when a lighter I-beam is a much better choice?
Scat Pro-series I beam - best bang for the buck rod on the market.
Originally Posted by wrd1972
That's what I got.
Me too! 6" rods, Mahle powerpack .027 cometics skosh over 12:1 compression Runs great.
Old Jun 29, 2008 | 04:47 PM
  #21
luckyou03's Avatar
I'm so ignorant about this subject. I don't know what a good ring pack is or what piston goes with what rod size or floating or pressed fit. If someone can link me to exactly what I should get from summit like llyod did. I was about to order those TRW pistons but I don't mind spending a little more for something better if I need to. I was going to use the stock crank and stock rods. I'm looking for forged pistons (.030 over) in I'm guessing SRP, Mahle or Wiseco?
Old Jun 29, 2008 | 11:31 PM
  #22
luckyou03's Avatar
What do you guys think about the TRW-LW-2256F30 pistons? They are suppose to be lighter and they have:
Bore (in): 4.030 in.
Bore (mm): 102.362mm
Piston Style: Flat top, with four valve reliefs
Piston Material: Forged aluminum
Compression Distance (in): 1.563 in.
Piston Head Volume (cc): +6.10cc
Wrist Pin Style: Press fit or floating
Pin Diameter (in): 0.927 in.
Piston Ring Thickness: 1/16 in. x 1/16 in. x 3/16 in.
Quantity: Sold individually.
Notes: Lightweight. Approximate compression ratios: 10.40:1 with 58cc, 9.72:1 with 64cc, 9.32:1 with 68cc, 8.96:1 with 72cc, and 8.62:1 with 76cc head.
Old Jun 29, 2008 | 11:47 PM
  #23
Still heavier than stock pistons by 30g
Remember you will need to have the rotating assy balanced with any of these pistons.
Old Jun 29, 2008 | 11:56 PM
  #24
luckyou03's Avatar
what about the rings? Is 1/16 in. x 1/16 in. x 3/16 in. better than 5/64 in. x 5/64 in. x 3/16 in.?
What kind of a difference will 30g make?
Also, ruff estimate how much would the balancing be?
Thanks!
Old Jun 30, 2008 | 01:35 PM
  #25
seawolf06's Avatar
Thanks!
Get the Mahle powerpack pistons and be done with it. They are much higher quality than the TRW's as well.
I only used H-beams because I found a package deal. I do wish that I had waited to check my deck height before getting head gaskets. I thought I'd have a zero deck, but the pistons ended up .010" in the hole which made my quench .049".
Old Jul 1, 2008 | 09:34 PM
  #26
luckyou03's Avatar
I just ordered a set of Manley Forged pistons (458 grams with pin) with Scat 6.0 Pro Comp I Beam Rods (610 Grams). Thanks for the help, I will definitely check before i order head gaskets.
Old Jul 1, 2008 | 11:08 PM
  #27
hosspwr94's Avatar
just a quick ? does anyone know the weight of the keith black Hypers (4.030 w/5.7)
http://store.summitracing.com/partde...&view=1&N=700+
Old Jul 2, 2008 | 08:49 AM
  #28
Javier97Z28's Avatar
Moderator
I run the Mahle powerpak and 6" Scat I-Beams.. my engine revs very quickly and happily.
Old Jul 2, 2008 | 11:17 PM
  #29
jclark311's Avatar
I will second the Mahle power pack, and Scat I Beam rods, here is the part numbers from Summit, this setup is for the 6 inch rods, you get Mahle Forged Pistons, Rings, Wristpins, Forged I Beam rods with 12PT ARP Rod Bolts, cost is about 850.00.
Mahle Power Pack SBC250030F05
Scat 2ICR-6000-7/16
LeftoverChinese
Jan 14, 2024 03:03 PM
Noer
Feb 28, 2015 11:29 AM
StansZ28
Feb 19, 2015 07:39 AM
Queens94z28
Nov 20, 2014 06:03 PM
