Rods and pistons for 7000 rpms
Old Sep 4, 2006 | 07:43 PM
  #16
Projectz28's Avatar
Moderator
Re: Rods and pistons for 7000 rpms
Building mine now, forged Eagle crank and rods, JE domed nitrous pistons. Should be able to handle 7500rpm and still be reliable. And cost is still somewhat in check at right around the $4k mark.
Old Sep 5, 2006 | 07:28 AM
  #17
SStrokerAce's Avatar
Few things....
1. Assembly and checking clearances/tolerances goes a long way to making things live. The problem is on "Chinese" stuff that the parts usually need more tweaking to work. Then again the best pistons I've ever used are imported, but thats from across the other ocean, not the pacific.
2. Mass and piston speed are two things that need to be thought about for long term durability. You can run a weaker crank and block with lighter parts and less piston speed. If you put more stroke or more RPM in a motor it beats up on cranks and blocks, so you need stronger cranks, lighter parts and better block prep (4 bolt etc..)
3. Good Chinese parts = Eagle, Scat. If the pin bores are tight on the rods, they need to be fixed. You need to measure and set bearing clearances on the rods and mains and use different size bearings to get them right if need be. There are varied reasons to use and not use them, but most times they are on the more affordable side of the scale.
4. Good American parts = Crower, Manley, Lunati, Callies, Howards. There are a lot more but that's the more budget orinented stuff. These guys make some good cranks and rods, same assembly procedures apply.
5. Pistons = Diamond, Mahle would be my top two favorites. JE/SRP is on my **** list, Weisco, Ross, CP, BME, Lunati, Manley, Probe are not something I use commonly but they are all good as well. I know Weisco and Diamond are in Pro Stock motors with the Professor and KB Racing (Anderson/Line), Mahle is a big time NASCAR and Sports Car racing supplier.
Bret
Old Sep 5, 2006 | 05:32 PM
  #18
marshall93z's Avatar
Bret
Speaking of clearances, I have a crank that has been cut .010/.010". What is there to do if I can't get my clearances where I need them? Unlike the standard crank where you can get +/- bearings.
Old Sep 5, 2006 | 07:04 PM
  #19
gex598's Avatar
I've been to 7000 plenty of times on a cast SCAT crank, SCAT Pro Series I-beams (6.125) and Cosworth pistons. Its still a two bolt block, and its taken the abuse of a 250 shot many times.
Jason
Old Sep 5, 2006 | 09:48 PM
  #20
Black6spdZ's Avatar
i turn mine 7k regularly with 4340 eagle crank, h-beam rods and forged srp pistons runs like a top. As said before though the clearances really need to be watched some of my wrist pin bores were too tight and needed to be honed.
Scott
Old Sep 5, 2006 | 09:49 PM
  #21
That's one of the reasons I don't like undersize stuff unless you measure your main journals with the bearings in them and grind the crank accordingly.
Bret
Old Sep 5, 2006 | 10:03 PM
  #22
978Racing's Avatar
Originally Posted by YZF/LS1 Freak
If you have the stock opti I doubt it will like those RPM's.
So who makes a better opti??
AL
Old Sep 7, 2006 | 03:57 PM
  #23
Bret
True...makes sense.
LeftoverChinese
Jan 14, 2024 03:03 PM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
Bill'sWS6
Aug 5, 2002 01:00 PM
