on the rod bearings do i need them with dowel pin hole or not
Old May 27, 2005 | 11:45 PM
93redlt1's Avatar
wondering which heavy duty bearings from clevite to buy
CLE-CB663H1 no dowel pin hole
CLE-CB663HD1 with dowel pin hole
BOth part numbers r from summit
Thanks for any advice
Old May 28, 2005 | 02:40 AM
MaxLean's Avatar
Re: on the rod bearings do i need them with dowel pin hole or not
Most likely, without. Unless you're running something fairly exotic.
Old May 28, 2005 | 06:30 AM
mohawkmike's Avatar
Dowel pins are used in some aluminum Con. Rods as insurance to keep the bearing from spinning. So, unless youre running Aluminum rods Dont go for the dowel pin bearings.
beltrunner
Apr 15, 2015 01:10 AM
carl.froehlich
Mar 13, 2015 12:38 AM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
