this is gonna sound real dumb but...
i was taking out my old headunit and removed a whole bunch of wires and now when i turn the key the car does nothing. no accessories, no dome lights, no nothing. i checked the battery and it reads 12.3V, i checked all the fuses they were fine, i checked the connection at the battery it was fine. what would cause the car to do nothing when the key is turned?
Re: this is gonna sound real dumb but...
i just cleaned off all the posts and it sparked when i reconnected the negative post but still nothing when i get in and turn the key. i tried disconnecting and connecting it again and now there is no spark. anyone have any ideas?
for your head unit there is a red wire and a yellow wire. yellow is straight from the battery, red is from the ACC pos. on the ignition. buy a DVOM (digital volt ohm meter)
i reset the comp and still nothing. i will try to see if the computer is getting power and if the head unit wires are getting power. i have a 94 trans am does it need to have a head unit hooked up for VATS or should it work without one?
