rockers wont stay tight
Old Dec 7, 2008 | 05:57 PM
blackz151's Avatar
What could it be lifters? Could it cause the car to run like crap?
Old Dec 7, 2008 | 06:09 PM
blackz151's Avatar
stockers btw
Old Dec 7, 2008 | 09:19 PM
That Camaro Guy's Avatar
Which method are you using to adjust your rockers?
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old Dec 7, 2008 | 09:36 PM
And to be more specific, yes it will cause your motor to run like crap if done improperly. Too loose will cause valve chatter that could trigger your knock sensor, pulling timing. Too tight could cause the valves to not close all the way, loosing compression. Shoebox's website might shine some light on your problem.
Old Dec 7, 2008 | 10:31 PM
blackz151's Avatar
i adj. them with the motor running they stop clicking for a min or 2 and then go right back to clicking and i can shake them by hand
Old Dec 8, 2008 | 01:09 PM
BUBBA's Avatar
Do they lock after adjustment? How are you locking them?
Old Dec 8, 2008 | 09:26 PM
nhill_05's Avatar
My guess is that the stock lock nuts have gone south on you. A set of positive locks and a good adjustment should set you straight....
Old Dec 8, 2008 | 10:24 PM
henryz28's Avatar
Are you having this problem with all the rocker arms?
Old Dec 9, 2008 | 12:34 PM
87bandit's Avatar
def check shbox
Boss002
Jul 24, 2015 10:47 AM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Noct
Jul 14, 2015 01:18 AM
