rockers hitting dual valve springs !! Help?
Old Dec 12, 2003 | 09:16 PM
INFERNO's Avatar
I just got my heads back from Lloyd Elliot and I had the dual valve springs put on the heads. The only problem that I am running into is that the original 1.6 RR that came with the hotcam kit are hitting the retainers of the springs. I ground a very little off the rocker but they still intefere. The roller tip is not touching the tip of the valve. I am using the stock 93 hardened pushrods. What should I do? I did a search and found nothing on this. I am using ARP rocker studs if it matters.
Old Dec 12, 2003 | 10:48 PM
Cman's Avatar
You may need different length pushrods depending on whether the installed height of the springs has changed when you went with dual valvesprings.
Did you put in new valves too? Most afkt. performance stainless valves have a longer valve stem height than stk. valves, this combined with the possibility of a higher installed height of the springs could cause your rockers to touch the retainers.
Get a pushrod checker to check the geometry of the valvetrain and to figure out what the proper length of pushrods you should use, this should fix your problem.
Tony
Old Dec 12, 2003 | 10:56 PM
INFERNO's Avatar
http://www.jorsm.com/~samartin/rocker.html
I think this may work.
Old Dec 13, 2003 | 01:45 AM
LilJayV10's Avatar
Tony
not nessicarily. Yes find out if the valves are stock length or .100 longer. just the pushrond length being different wont cause it to hit. More than likely that has happened is you have a bigger diameter spring. This happened to me with my 406. The set of protopline heads I got had bigger springs on it for a roller cam, I mean the outside diameter of the spring is larger, you can only run so much lift on a stock sized spring, to keep seat pressure up you have to go with a larger spring. the problem is the bottom part of the rocker is to big because most rockers are desinged for stock sized springs. I have a set of crane engergizer 1.6's on my 406, my buddy was going to swap me for a set of harland sharp 1.6's. I went through all the trouble of putting my rockers on his car, then went to put the harland sharps on mine and the damn things wouldn't fit. So i had to swap them back, for some reason the cranes where made to accept the larger springs. I have seen people grind the rocker arms down so it will clear the spring, and they also sell different rockers for bigger springs. Hope this helps some. I think this might be your problem but without being there I can't say 100%
Jason
Old Dec 13, 2003 | 02:01 AM
SVT Killer LV's Avatar
my harland sharpe rockers did the same thing gave those to a buddy, and put my pro magnums on.. best move i ever did..
cc pro magnums>every other stud rocker
Old Dec 13, 2003 | 11:23 AM
Cman's Avatar
To install larger springs on LT1 heads don't you have to machine the spring pockets for them to fit? The original poster mentioned that he has a LT4 hotcam kit on his engine. I take it that would mean he has LT4 springs on there. They should be stk. diameter size and his rockers shouldn't really touch the retainers at all if everything else checks out.
I'm running the Crane 10308 kit on my heads with Crower SS rockers didn't have any problems with the rockers hitting the retainers. I also changed my pushrods to CC chrommoly ones don't remember if they were a different length or not but I did check the geometry to get the right length PR's before ordering them. My heads are stk., haven't touched them.
Old Dec 13, 2003 | 01:15 PM
NightTrain66's Avatar
They are longer valves and dbl springs. I would use an adjustable length pushrod and check geometry. At 1/2 lift, the roller rocker wheel should be centered on the valve. If this means a longer pushrod, COOL and you might be able touse these rockers. If it needs a shorter pushrod, some serious grinding would be needed on the rockers.
If this is the case, some NSA rockers with more clearance in this area and guide plates would be the best set up.
Gimme a call if you need ANY help figuring it out.....Good Luck.
NightTrain66
Old Dec 13, 2003 | 04:30 PM
LilJayV10's Avatar
If you need a .100 longer pushrod, let me know, i have a new set of trick flow 7.3's for sale.
Jason
oldschool
Feb 9, 2016 09:21 PM
nikolt1
Feb 27, 2015 09:10 PM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
