Which rocker stud to use
Old Mar 28, 2004 | 04:39 PM
NAZTLT1's Avatar
I have CC 7/16 1.6 nsa rockers so I need to use gm guide plates. I want to use arp rocker studs. Which part# would be the correct one to use with guide plates. Should I be concerned about compensating for the amount of thread that will not be fastened to the stud bosses due to the guide plates or is it insignificant?
Bottom line is, what rocker studs should I be using.
Old Mar 28, 2004 | 08:40 PM
Bud M's Avatar
I don't have the part number but the amount on stud length you lose going through the guideplate is not significant. Go to the Comp Cams website for the part number.
Old Mar 28, 2004 | 08:49 PM
FastWhiteTA's Avatar
I used the ARP 7/16" studs and GM guideplates w/ 1.7 roller rockers. No problems here, and that's w/ multiple times in the 6300 rpm range, and a few 6500 rev limiter bounces.
Old Mar 30, 2004 | 08:25 AM
NAZTLT1's Avatar
How about pushrods? I know I will need hardened but can I still use the stock length.
Can anybody give me a part # for the correct pushrod?
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
