Which rocker stud to use
I have CC 7/16 1.6 nsa rockers so I need to use gm guide plates. I want to use arp rocker studs. Which part# would be the correct one to use with guide plates. Should I be concerned about compensating for the amount of thread that will not be fastened to the stud bosses due to the guide plates or is it insignificant?
Bottom line is, what rocker studs should I be using.
