Rocker stud question
Old Feb 23, 2004 | 05:11 PM
Brandon94Z28's Avatar
I got 1.6 nsa roller rockers and with the guide plate on the stud only goes into the head 3 turns. Anyone know the arp part number for a stud that goes into the head like 1/4 further?
thanks guys,
Brandon
Old Feb 23, 2004 | 06:59 PM
12SCNDZ's Avatar
ARP # 7201...Also make sure you've got the correct guide plates. The ONLY ones that work are GM part # 14011051. Nothing COMP , Crane, or ANY other cam manufactuerer will work. LT1's have .050" different valve spacing than a typical SBC. Isky makes a set of "adjustable plates", but they have to be welded after they're adjusted. The GM Performance plates are a "bolt-on" deal.
Frank
Old Mar 6, 2004 | 05:28 PM
steve-d's Avatar
Are Guide plates advisable when using the GM LT4 rollers? They come as a kit w/springs etc, but no guide plates.
Steve
Old Mar 6, 2004 | 06:25 PM
Steve
AFAIK, the LT4 rockers are self-aligning and don't require guide plates. It is not advisable to use guide plates with self-aligning rockers.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
alphaauto
Jan 23, 2015 07:42 AM
95chwagon
Jan 13, 2015 09:19 PM
