Rocker/lifter noise only at certain RPM?
Old May 16, 2008 | 10:12 PM
camarozz95's Avatar
Ok so I've had my rockers installed for about 2 weeks drives great. My question is valve train is quiet at idle maybe a little louder than stock but not clicking or anything car is quiet while driving no problems, But I have noticed that when driving very slow like in a parking lot or so rpms at like 1200 to 1500 range, or when driving and slowing down once the rpms get into that range it sounds like a loose rocker kind of but definitely not as loud. Is this normal for 1.6 SA rockers cause other wise they are quiet.
Also I pulled the valve cover and reved the engine and it sounds normal, but if you sitting in traffic in between cars if I rev to about 1200 and hold you can hear some clicking that sounds kinda like a loose rocker kinda weird cause it only does it then. Hope this is normal noise for the rockers.
Thanks In advance
Old May 16, 2008 | 10:14 PM
Stl94LT1's Avatar
Sounds normal, especially if it is fairly quiet at idle.
Old May 16, 2008 | 10:59 PM
camarozz95's Avatar
haha ok good I was pretty sure it was I just needed some reassurance.
Old May 17, 2008 | 12:06 AM
mrmint69's Avatar
If you tightened them correctly then your probably ok. I know stock rockers are different than aftermarket when adjusting them.
Old May 17, 2008 | 10:52 AM
What is your oil pressure at idle/low rpm? If its too low, it may increase the lifter noise.
Old May 17, 2008 | 11:32 AM
MarcR94v6's Avatar
Mine are like how you describe stock, is this bad? I've replaced the lifters recently, maybe I need to adjust the valves.
Old May 17, 2008 | 02:18 PM
camarozz95's Avatar
Oil Pressure is good at idle its always right on or right above the first white tick mark.
colts0455
13
Aug 7, 2015 09:15 PM
techstar
Aug 6, 2015 11:20 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
