camarozz95 |
05-16-2008 10:12 PM |
Rocker/lifter noise only at certain RPM?
Ok so I've had my rockers installed for about 2 weeks drives great. My question is valve train is quiet at idle maybe a little louder than stock but not clicking or anything car is quiet while driving no problems, But I have noticed that when driving very slow like in a parking lot or so rpms at like 1200 to 1500 range, or when driving and slowing down once the rpms get into that range it sounds like a loose rocker kind of but definitely not as loud. Is this normal for 1.6 SA rockers cause other wise they are quiet.
Also I pulled the valve cover and reved the engine and it sounds normal, but if you sitting in traffic in between cars if I rev to about 1200 and hold you can hear some clicking that sounds kinda like a loose rocker kinda weird cause it only does it then. Hope this is normal noise for the rockers.
Thanks In advance
