Rocker install questions
Old Feb 18, 2005 | 01:10 PM
Tekprodave's Avatar
Question Rocker install questions
I'm planning to use LT4 valve springs so do I need new valve shims to hold the bottom of the spring?
Also, do I need to replace the valve seals on a car with 72K mi?
Thanks in advance,
Dave
Old Feb 18, 2005 | 01:23 PM
Re: Rocker install questions
LT4 springs should go right in without any shims, but it is always a good idea to check installed height.
IMO, always replace the valve seals when you have the springs off (unless extremely low miles on the seals). It just doesn't make sense not to.
Old Feb 18, 2005 | 03:15 PM
Tekprodave's Avatar
Awesome info!! Thanks a bunch!!
LeftoverChinese
Jan 14, 2024 03:03 PM
oldschool
Feb 9, 2016 09:21 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Chrisdude
Jul 24, 2002 02:25 PM
