rocker for comp 977's?
Old Mar 31, 2004 | 04:42 AM
dhirocz's Avatar
I just found some info that says that comp pro magnum's aren't recommended for over 350ish pounds open pressure...and Comp 977's are in the 400+ range. If this is true, what roller rocker are you 977 guys using on your heads? I plan on using 7/16 studs and aftermarket pushrods, I just need rockers...here's where I wish I had the money for shaft mount rockers
Old Mar 31, 2004 | 04:47 AM
rskrause's Avatar
Moderator
Whever you heard that, it's incorrect. Some aluminum rockers carry a reccomendation like that, but I have used 977's with aluminum rockers, so you will be fine with the Pro Magnums. If you want, you can get Comps stainless rockers, but they are definitely not needed.
Rich Krause
Old Mar 31, 2004 | 06:58 AM
AHARTZ28's Avatar
pro mags will work great. alot of poeple run them on solid roller set ups i did.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
