rocker arms
Old May 13, 2009 | 10:33 PM
Gio93z's Avatar
rocker arms
Can I just have some clarification in regards to non self-aligning rocker arms and self aligning rocker arms. My application is in regards to a 93 LT1 with AFR heads. I am getting new full roller rocker arms but just need to clarify what direction I need to go in.
Thanks!
Old May 13, 2009 | 10:47 PM
NSA's use pushrod guideplates for alignment. More stable for more frequent high RPM or racing use.
SA's use little tabs on the sides of the end of the rocker that contacts the valve stem.
Old May 14, 2009 | 06:14 AM
rskrause's Avatar
Moderator
If the heads have guide plates, you must use hardened pushrods and NSA rockers. This is preferable to SA rockers for hi-po use anyway.
Rich
Old May 14, 2009 | 01:44 PM
mzgp5x's Avatar
I've used Crane Gold SA rockers with AFR 190 heads. I went to Comp ProMag's with 7/16 studs. I had to mod my pushrod plates, but, the Comp RR's w/ 7/16" studs are alot more rigid and true running than SA rockers (my opinion) (Isky makes an adjustable PR plate guide). (App... 97ss 383ci D1 AFR 190 heads MM6). HTH B.
Old May 14, 2009 | 05:13 PM
Gio93z's Avatar
alright so im basically going with hardened pushrods and NSA RR's......
thanks everyone
Old May 14, 2009 | 11:27 PM
Hal Fisher's Avatar
And guide plates, right? You need those or else the rocker will slip off the valve head. From all I've read the GM flat ones are the way to go.
Hal
Old May 15, 2009 | 12:38 AM
Gio93z's Avatar
yea they already have the guide plates....im just trying to find a full RR that is NSA, 1.6, and will fit center bolt valve covers.....
Old May 15, 2009 | 01:02 AM
Hal Fisher's Avatar
Scorpions, Crane Golds, Comp Mags. Can you handle 1.7s? Then go with Scorpions otherwise their 1.6 are cheap and Crane Golds are good and quiet as well.
Here is a source for the Scorpions: http://www.flatlanderracing.com
Hal
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
