rocker arms
rocker arms
Can I just have some clarification in regards to non self-aligning rocker arms and self aligning rocker arms. My application is in regards to a 93 LT1 with AFR heads. I am getting new full roller rocker arms but just need to clarify what direction I need to go in.
Thanks!
Thanks!
I've used Crane Gold SA rockers with AFR 190 heads. I went to Comp ProMag's with 7/16 studs. I had to mod my pushrod plates, but, the Comp RR's w/ 7/16" studs are alot more rigid and true running than SA rockers (my opinion) (Isky makes an adjustable PR plate guide). (App... 97ss 383ci D1 AFR 190 heads MM6). HTH B.
Scorpions, Crane Golds, Comp Mags. Can you handle 1.7s? Then go with Scorpions otherwise their 1.6 are cheap and Crane Golds are good and quiet as well.
Here is a source for the Scorpions: http://www.flatlanderracing.com
Hal
Hal
autoxr166
Sep 25, 2015 04:21 PM
