rocker arms??
Old Jul 10, 2005 | 03:53 PM
lt1street's Avatar
rocker arms??
Does the lt1 use the standerd or different rollar rocker then a regular 350 or is it the same. Also valve spring same or different???? Looking though a summit or jegs you some time see lt1 rollar rocker then some time you dont see any listing. woundering if it just a money maker or do the really have a different setup?
Old Jul 11, 2005 | 07:07 AM
ProjectJ's Avatar
Re: rocker arms??
The LT1 requires that you use self-aligning rockers (unless you modify the heads to use screw in studs and guideplates).
Old Jul 11, 2005 | 07:13 AM
NBred94's Avatar
Re: rocker arms??
Aluminum head LT1's do not require any modification to use screw in studs. If you decide to use NSA (non-self aligning) rockers, you will have to use guideplates as mentioned above, but the stock rocker arm studs are screw-in type. ARP makes longer (for the guideplates) replacement screw-in type studs specifically for our application.
If you go to Thunder Racing's site and search by vehicle, you can see all of the specific stuff available for the LT1. I just swapped out my rockers a couple of weeks ago.
Old Jul 11, 2005 | 08:22 AM
rskrause's Avatar
Moderator
Re: rocker arms??
If you are thinking of aluminum roller rockers, you need to get a model designated to use with center bolt valve covers, they are narrower than the rockers made for perimeter bolt covers.
Rich
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
