rocker arm torque
Old Mar 14, 2007 | 03:58 PM
pattracing212's Avatar
rocker arm torque
just wondering if anyone knows off hand what the torque specs are for 1.6 rr's. and if anyone has ns/a 1.6 rr's with guideplates on their car. i would like to see a picture of how everything looks done so i have an idea.
Old Mar 14, 2007 | 04:11 PM
FryedClutch's Avatar
uhhhhhh 1/4 or half turn past zero lash for optimal power
stock specs are 3/4 to 1 full turn past zero
or do you mean the torque spec on the rocker stud into the head?
if thats the case i dunno of the top of my head but id guess idunno 40 ftlbs
but dont quote me on that
Old Mar 14, 2007 | 04:13 PM
yeah.. i just needed the torque specs of th erockers not the studs
Old Mar 14, 2007 | 04:30 PM
2000GTP's Avatar
The rockers themselves don't have a defined torque value, as mentioned above, you set the valve lash: http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old Mar 14, 2007 | 04:47 PM
BUBBA's Avatar
Here's one for ya: Why do you say that for optimal power only go 1/4 to 1/2 when if that is the case why would anyone go beyond 1/4---or even 1/8th?
Old Mar 15, 2007 | 09:49 AM
OBE1 95Z28's Avatar
As stated above, you don't mount rockers by setting a torque value, you need to set the lash (amount of spring force the lifter places on the pushrod/rocker/valve). Here's a link to several lash setting procedures on Shoebox's site: http://shbox.com/1/4th_gen_tech2.html#adjust_valves
browenb
Parts Wanted
Jul 20, 2015 07:34 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
94Form
Jul 17, 2015 10:56 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
