rocker arm stud spacing ???
Old Dec 4, 2006 | 11:38 PM
Mean Green's Avatar
does anyone know the spacing between each rocker arm stud on a set of LT1 or SBC heads? looking for the center to center spacing.
Old Dec 5, 2006 | 03:46 PM
Mean Green's Avatar
bump
Old Dec 5, 2006 | 11:27 PM
seawolf06's Avatar
I'm getting about 1.8"
Old Dec 6, 2006 | 12:47 PM
Mean Green's Avatar
alright since apparently no one knew this in the other sections I figured some of you engineers might.
I'm looking for the center to center spacing between the rocker arm studs on an LT1 head. I think the spacing between the valve centerline is the same, but I'm not sure. hopefully someone with a little bit of technical knowledge of the LT1 can help me out.
in the pic below say the circles are the studs. I distances X and Y.
Old Dec 6, 2006 | 01:59 PM
SStrokerAce's Avatar
Same as the GM Bowtie Heads. The spec on the distance between the centerlines of the valves on those is 1.91". Those are the heads who's guideplates we use now on LT1 stuff all the time. I might be able to go accurately measure them in the shop as well, but I'm 99% certian that this is the spec for them.
Bret
Old Dec 6, 2006 | 02:24 PM
seawolf06's Avatar
Yeah, I measured 1.91 between the valves, but only 1.8 between the rocker studs. Do I have the wrong heads? haha.
Old Dec 6, 2006 | 02:53 PM
No that's very normal, the rocker placement and the valve placement are different.
Old Dec 6, 2006 | 02:58 PM
seawolf06's Avatar
Bret, you have got to be the greatest resource this board has. If you ever find yourself in south Louisiana, let me know and I'll buy you a beer!
Old Dec 6, 2006 | 04:33 PM
I vote shoebox for that honor!
Old Dec 6, 2006 | 05:19 PM
Dave89IROC's Avatar
agreed
Old Dec 6, 2006 | 11:44 PM
seawolf06's Avatar
Ok, I stand corrected...but I still to both.
Old Dec 7, 2006 | 03:42 PM
seawolf06's Avatar
I answered your other post, as did Bret. But I'll try again.
x=1.8"
y=2.8"
Old Dec 11, 2006 | 05:27 PM
Mean Green's Avatar
ah...finally found this. I wondered where it had gone. Thanks for the answers guys. It really helps me out.
Old Aug 20, 2015 | 12:25 PM
new2chevy's Avatar
Re: rocker arm stud spacing ???
Ok so I've been wondering about this too.
So I could conclude that a rocker stud girdle for the "bow tie" head will properly line up with my factory LT1 head's rocker studs?
I ask because there are no rocker stud girdles available for the LT1.
Old Aug 20, 2015 | 03:04 PM
Crane:
http://www.summitracing.com/parts/cr...1/applications
Here it is on an LT1 - note perimeter bolt conversion for valve cover:
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
94Form
Jul 17, 2015 10:56 PM
