rocker arm stud?
Old Jan 14, 2008 | 06:36 PM
guest74777's Avatar
Guest
rocker arm stud?
Im switching to NSA rockers this winter with the GMPP guideplates, is the stock rocker going to have enough thread in it to screw into the head? if not, which 3/8 studs should I buy... part numbers if you guys could help me, thanks alot.
Old Jan 14, 2008 | 06:44 PM
Try2Catchme's Avatar
Post
I would use the ARP studs.. have had good luck with them. if i get a chance i will try get my part a part number.
Old Jan 14, 2008 | 09:05 PM
greenmachinedriver's Avatar
if you are making the change to nsa you may as well upgrade to 7/16 studs. you have to change the studs anyway and they dont cost anymore. +1 for arp
Old Jan 14, 2008 | 09:58 PM
Check the GM guideplates for hardness before you put them on. Some have been reported to not be hardened properly.
Old Jan 15, 2008 | 08:12 AM
guest74777's Avatar
Guest
how would i check them for hardness???
Old Jan 15, 2008 | 08:29 AM
mzgp5x's Avatar
A fine tooth file will skip off the edge of the guide piece (lite force). Check it near the groove. Do not touch the PR groove. A file will bite into soft metal. B.
Old Jan 15, 2008 | 11:07 AM
Stl94LT1's Avatar
Get the Trickflow guide plates and you won't have to worry about the hardness issue. Oh, and they're cheap ~$15.
Quickss96
Jan 29, 2016 05:56 PM
FryedClutch
Sep 1, 2015 08:24 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
