Rocker arm ratios
Old Feb 22, 2009 | 10:20 AM
Jlo's Avatar
Jlo
Rocker arm ratios
I was thinking of running either a cc503 or an LT4 hot cam on my 95 z28. One question I have is will I gain anything if I go with a rocker arm ratio of either a 1.65 or a 1.7 is there any HP increase than the 1.6 I know I'll get more lift but what will that translate to? Other than probably a stronger spring what else will I need to make this work I'll measure the Push-rods to make sure I'll have the correct geometry on the valve train. This is going on a rebuilt LT1 with 2-valve notch pistons. Any input would great...
Jlo.
Old Feb 22, 2009 | 10:41 AM
Stl94LT1's Avatar
I've heard pros and cons of 1.7 rockers on valvetrain geometry. Why not just have a camshaft ground with your desired lift with 1.6 rockers. Also, if you are running stock heads the extra lift may not be benificial.
Old Feb 22, 2009 | 11:35 AM
87bandit's Avatar
I was always under the impression that it's better to have true lift (cam ground lift) than artifical lift (manipulating lift with higher ratio's than 1.6)
Old Feb 22, 2009 | 02:08 PM
96m6lt1's Avatar
there is nothing wrong with using the 1.7 ratio,geometry is not too much of an issue.
quite a few have had nice gains over 1.6s. a few bolt on cars have made 10 more at the wheels by using 1.7s ....stealth like,easier and cheaper than doing a cam swap.what is the average cost in adding hp? if you can do it without breaking the bank,by all means do it!
i have heard the same however adding longer rockers to gain more lift is a fast efficient way to add more power...lift is lift however you can get it!
there are a bunch of NMCA racers that use rocker ratios to manipulate lift(increase or decrease) nothing wrong with it .
Old Feb 22, 2009 | 02:40 PM
Jlo's Avatar
Jlo
Stock heads yes, but they will be sent out to get ported in a month. I guess what I wanted to know was that if anybody tried this and what they got out of it by using a bigger ratio.
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
realistyc
Jul 28, 2015 07:32 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
JCSWS6
Jul 19, 2015 06:47 PM
94Form
Jul 17, 2015 10:56 PM
