rocker arm keeps falling off
Old May 14, 2005 | 02:14 PM
Trannykiller's Avatar
i dont know what is making this happen, but every time i do a highway run and i decelerate the same rocker arm on the same cylinder falls off. They are the crane 1.6 magnums with CM 614 spings and hardened pushrods. The pushrod has never bent. The rocker arm just swivels off sideways. I tried swaping rocker arms to a diff cylinder along with pushrods. but the same thing keeps happening. I dont know if its a failed lifter or maybe bent rocker stud possibly coil bind? Any input would be apreciated. its a 94 A4 mods are intake catback and 1.6ers
Old May 14, 2005 | 03:24 PM
streetbad's Avatar
Re: rocker arm keeps falling off
Put in a little more preload. Make sure you are on the base circle of the cam when setting preload. TIGHTEN the nut VERY hard.
Old May 14, 2005 | 03:53 PM
i was doing 1/4 turn past the clack. Guess ill try half turn, what makes it a bitch is its passenger side so the alt and serp belt always has to come off its happend 3 times now. i set then 1/4 past clack with the motor running just because too tight can cause problems. From my understanding the looser it is without clack or ticking the better.
Old May 14, 2005 | 05:19 PM
1racerdude's Avatar
Ya running SA rollers? If not ya got the correct guide plates? The GM and Isky adjustable are the only ones that work.
Old May 14, 2005 | 06:39 PM
96ta(nick)'s Avatar
Found that out the hard way.. Comp's don't work.. Switched to GM and they are great.
Old May 14, 2005 | 09:04 PM
If adjusted properly, maybe the lifter is collapsing.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
