Rocker Arm install
Old Apr 26, 2004 | 09:02 PM
Built on Sin's Avatar
Rocker Arm install
I just installed 1.6 rr and I think something might be wrong.
Should the intake and exhaust rockers be perfectly parallel to each other?
Most if not all, of mine are somewhat nonparallel.
Old Apr 26, 2004 | 09:13 PM
ibanez6rg's Avatar
NSA or SA rockers?
Old Apr 27, 2004 | 12:31 AM
Lt1t56's Avatar
I just finished head gaskets and using crane self aligning rockers, before and after I took heads off the rockers werent perfectly aligned.
Old Apr 27, 2004 | 10:09 PM
Rockers are NSA.
Also, the valve covers won't even come close, to clearing the rockers.
Did I do something wrong?
Old Apr 27, 2004 | 10:11 PM
Aeromaks's Avatar
there are some rockers than go on perfectly that you will not have problems with valve covers, with some you will, what brand of rockers?
Old Apr 27, 2004 | 10:16 PM
CeeBee94Z's Avatar
More then likely you will have to modify the valve covers slightly to get them to fit under there. I just used a set of pliers and flattened the "webs" so there wasn't the little L shaped bend on the bottom and that worked perfectly.
Old Apr 27, 2004 | 10:17 PM
pro magnum 1.6 nsa with pushrod guideplates.
Old Apr 27, 2004 | 10:23 PM
ibanez6rg's Avatar
Should fit under stock valve covers with modifying/clearencing.
Old Apr 27, 2004 | 10:31 PM
97bowtie's Avatar
Ditto.
Old Apr 27, 2004 | 10:50 PM
What guideplates are you using? Some don't align well. GM p/n 14011051's do.
Old Apr 27, 2004 | 11:02 PM
Umm, I don't know? Whatever CMotorsports gives in their kit.
Yes, they are the reason I had trouble keeping the rockers
straight. Will they be ok, this way?
Anybody have a how-to on modifying these valve covers?
I need about a 1/4" for them to fit.
Old Apr 27, 2004 | 11:46 PM
Better centering with the GM plates. I had the CM ones to begin with.
Some good pics of valve cover modifications at the bottom of this page.
Old Apr 28, 2004 | 12:19 AM
Joe Brodman's Avatar
GP Moderator
The LT4 valve covers don't require any clearancing. Well, unless you have Crane guideplates (I made that mistake), then you have to do a bit of grinding. The GM and Comp guideplates shouldn't require any modifying at all. I choose this route because not only do they look better IMO (especially w/ the MBA billet trim kit), they quiet down the valvetrain noise a bit.
carl.froehlich
Mar 13, 2015 12:38 AM
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
newby
Jul 25, 2002 03:22 PM
