Rocker Adjustments...Hot or Cold??
Old Sep 27, 2011 | 02:19 PM
ZX636RIDER03's Avatar
I need to adjust my GM performance roller rockers and was wondering if it makes a difference to have the Engine warmed up or to have it dead cold to get the best results. For some reason im thinking that cold is better due to the expansion of metal when they are warm. Does this make sense or is doing it when its warm the best solution.
Old Sep 27, 2011 | 02:24 PM
RamAir95TA's Avatar
Re: Rocker Adjustments...Hot or Cold??
As long as the rockers are pumped up it shouldn't matter.
Old Sep 27, 2011 | 02:34 PM
do you mean the lifters or the rockers? Can that be achieved by releasing pressure from the lifter by loosening the rocker or just simply running the engine?
Old Sep 27, 2011 | 02:41 PM
RamAir95TA's Avatar
Typo - of course I meant lifters.
Old Sep 27, 2011 | 02:50 PM
In the case of solid lifters, lash is set hot. Hydraulics don't matter so much, because of the wide preload variation they can handle. Most of the time, if you set it cold, you are good to go.
Old Sep 27, 2011 | 03:28 PM
Alright, thanks for the advice on this.
Wart Hog
Sep 8, 2015 05:53 AM
alphaauto
Jul 26, 2015 04:40 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
