Rip in LT1 intake elbow. What do?
Old Jun 17, 2016 | 01:29 PM
Aetheric's Avatar
Awkward rip in the air intake elbow right underneath the hose clamp. I'm strapped for cash so what cheap fixes can I do to this real quick? The car is running bit sluggish from it. I thought I could duct tape it real quick but it's an awkward fold of the intake so tape might not work that well. Could I use Permatex #2 form-a-gasket there? I'm being especially careful hence asking you experienced guys first. I don't want anything foreign being pulled into the block.
Old Jun 17, 2016 | 03:57 PM
Re: Rip in LT1 intake elbow. What do?
What year is the car? A rip in the elbow lets air bypass the MAF sensor (94-97). That screws up the fueling.
Old Jun 17, 2016 | 04:21 PM
Aetheric's Avatar
It's a 94 Z28. Bone stock.
I just did my first Optispark job on it and immediately got worried because it was running sluggish; feels like it lost some power. I was hearing a weird air winding sound too so I opened the hood up and saw the nice rip in the elbow.
Old Jun 17, 2016 | 04:35 PM
Chimera96's Avatar
difficult part/area to repair with tape but it may "reduce" some of the un-metered air entering the motor
Try contacting a salvage yard. If you could find one, should be around $5-$10
Maybe someone in FS section has one
RTV or other type sealant...I would be cautious of getting any sucked in motor.
Old Jun 17, 2016 | 10:46 PM
deebee's Avatar
I wouldn't seal anything like that as I would worry about it getting sucked into the engine.
Would it be possible to cut a plastic patch, say from an antifreeze jug or something similar, put it over the rip and then duct tape over it? I would make the patch a few inches wider than the rip.
That is the first thing that came to mind, not knowing how awkward of a spot it is to get to.
Old Jun 18, 2016 | 11:18 AM
timnfxr's Avatar
Another idea is to use thin gauge aluminum (ala HomeDepot) and cut a strip that is the width of the flat area of the elbow where the clamp is (TB side). And clamp it using the original clamp. It should definitely help.
Putting the elbow on the TB correctly can be awkward. I've resorted to disconnecting the MAF side and putting my hand inside the elbow to guide the bottom of the elbow/TB fitting to avoid tearing it.
Old Jun 18, 2016 | 01:17 PM
Aetheric's Avatar
Good ideas! Yeah my car has seen a few winters and is getting fragile. And you're right, that intake elbow is especially annoying to get on the TB when it starts to warp from old age.
Old Jun 18, 2016 | 07:00 PM
graham's Avatar
https://www.summitracing.com/parts/t...DeUaAuMq8P8HAQ
plattted
9
Sep 20, 2015 11:23 AM
Jcastro2333
Jul 27, 2015 09:49 PM
jmadoll
Jun 29, 2015 11:21 PM
Dzmaro
Jun 19, 2015 11:38 AM
Fatdog2
Jun 13, 2015 11:18 PM
